Gadget Gift Ideas For Everyone
I'm new to this forum and I'm a newbie at building a pc. Last time I build one was way back in 02 or 03 (P4 system). My friend was upgrading so he sold some of his parts to me for dirt cheap. Stuff I bought from him: Antec P180 mini case, Antec 500w earthwatt power supply, pioneer sata dvd burner & HIS 4870 1GB. (All for $200) All I need is processor, motherboard, memory and a network card. All I do with my computer is surf the net and play mild game. I am in a tight budget($300) and need your advise. Which one should I get? Intel Q8200($120) or Q9400($160) at a local shop or get a AMD X4 920 @ newegg.com for $150? And my friend said I need a atx mirco motherboard with DDR2 memory. Is 4gb of DDR2 667 good for my build? I will be installing Vista home premium 64 bit.
It doesn't have to be DDR2 and you won't need a network card.
I'd go with the phenom II on that list, an AM3 mobo and 4GB DDR3.
EDIT:Others have better knowledge of AMD mobos than me, so I'll wait for them rather than give you bad advice...
Most motherboards have built in network adapter.
It doesn't have to be DDR2 and you won't need a network card. I'd go with the phenom II on that list, an AM3 mobo and 4GB DDR3. EDIT: Others have better knowledge of AMD mobos than me, so I'll wait for them rather than give you bad advice...
I looked at newegg.com and only found 1 AM3 micro atx motherboard(DFI LP Jr) and it's kinda has a bad reviews and its kinda pricey. If you know if theres other AM3 micro atx board, let me know.
Sorry, overlooked mATX.
mobo:http://www.newegg.com/Product/Prod [...] 6813157160CPU:http://www.newegg.com/Product/Prod [...] 6819103471RAM:http://www.newegg.com/Product/Prod [...] 6820231184
Under $300, enjoy!
Edit: I listed better RAM.
