Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Gateway power adapter pin missing
Forum Motherboards & Memory : General Motherboard - Gateway power adapter pin missing
Hello all. Ive got an older gateway laptop that is missing the single pin for the AC power supply. Does anyone know if i can easily replace it? Or will i need to replace the entire motherboard?
Sponsored Links
I'm not familiar with gateway laptops. Is the pin on the laptop or in the AC adapter plug?
Reply to FallenSniper
I am guessing that you are talking about having a two prong AC plug instead of the more standard 3 prong plug.
When you say "missing" do you mean there's a place for it and it's broken off or something? Or do you mean it never had one?
If it's broken, just get a replacement AC cord. If it was never there, do not worry about it.
Why on earth would you think you need a new motherboard?
Reply to jsc
Sorry for the confusion, I'm talking about the 1-pin female port for charging the laptop. It's on the back of the unit...at one time the pin was inside the round adapter hole for the power supply
Reply to Justanox
Its in the laptop. I tried opening the laptop by removing all the screws, but i've got all visible screws out and it still wont open.
Reply to Justanox
There are 821 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
