Usb device not recognized (Mass Storage) but optical mouse works???
Get two pop ups #1 device not reconized, #2 device can run faster in listed ports. This is a new problem.
3 answers Last reply
More about device recognized mass storage optical mouse works
    Same as your other post ?
  2. 1. device not recognized when windows cannot locate the drivers automatically, locate the drivers for the device and install them prior to using the device
    2. your usb controller is too old for the device you're trying to use (most likely you got the old computer with old USB controller 1.2 and you're trying to use a USB 2.0 standard device with it)
  3. I spent a whole day troubleshooting my new windows 7 system. It did not see my external hard drive and I kept getting USB not recognized code 43 errors. Other usb attached devices worked fine but it would not recognize my Seagate drive. I tried pulling the battery to reset CMOS, tried deleting all the USB host controllers, tried all the Seagate help forum suggestions as well. It requires en edit to registry. Use this link to get it ...http://www.youtube.com/watch?v=SPEuacutH8A . Or here is the narrative.. This problem occurs when no device is connected to a USB port. That makes the USB driver set the Open Host Controller Interface (OHCI) controller to a suspended state. When the OHCI controller is in a suspended state, it cannot always detect when you add a new USB device to your computer.
    1 Click Start, click Run, type regedit, and then click OK.
    2 Locate and then click the following key in the registry: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\USB
    3 On the Edit menu, point to New, and then click DWORD.
    4 Type DisableSelectiveSuspend, and then press ENTER.
    5 On the Edit menu, click Modify.
    6 Type 1, and then click OK.
    7 Restart the computer.
    If the value of the DisableSelectiveSuspend registry entry is set to 1, the Selective Suspend feature is disabled.
Drivers Mice Storage USB Devices Windows XP
