Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > I7 Build CM 690 GTX260 SLI Heat Problem
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - I7 Build CM 690 GTX260 SLI Heat Problem
Hello to all:
My Build:
i7 920
2 GTX260's in SLI
Cooler Master CM 690 Nvidia Edition (With all 7 case fan slots filled with stock & Best Buy quality 6x120mm and 1x80mmx15mm)
6 GB Corsair XMS3 DDR3
Corsair TX850 PSU
Asus P6T MOBO
Vista 64
Noctua 1366SE CPU Heatsink
My Problem:
With GPU (and all other fans) at 100%, after about 15 minutes of Furmark stability test GPU's hit 90c or so and crashes system. It also happens when gaming for about 45 minutes.
My Question:
How can I lower my GPU temps?
I'm looking for suggestions from other people who have had success lowering their GPU temps. I know I'm having an airflow path problem due to the massive graphic cards and extra cables from the PSU. The intake fans are at the bottom, front, and sides of the case. The exhaust is the 2 120mm on top and the 120 in the rear. Would swapping all the fans out with higher CFM fans work to overcome the 10.5" graphic cards and extra PSU cables that are blocking the airflow?
I'm open to cutting some holes in my case to add a fan or 2 (the system is loud as h*** already), but the perfect place to mount the fan would require me to cut into the plexiglass or plastic or whatever it's made out of window on the side on the case.
FYI I had CPU heat problems as well. The Noctua CPU cooler cured them by dropping the 100% load temps from 100c to 60c (3.8 Ghz OC) in the Prime95 Torture Test.
Thank you in advance for your replies.
Sponsored Links
How do you have your fans setup? Front fan should be blowing in, Door fan should be blowing in, Case bottom fan should be blowing in, Rear fan should be blowing in and the two top fans should be blowing out. Just remember. Cool air sinks and hot air rises.
I would also look into some high cfm fans. Newegg has some quiet yet powerful ones.
Message edited by PsychoSaysDie on 06-23-2009 at 05:52:33 AM
------------------------------ Dell Precision 670
Dual 2.8Ghz SL8MA's
16GB DDR2
XFX 5770
Reply to PsychoSaysDie
That is exactly how I have my case fans setup.
Like I said I'm using all 120mm Cooler Master stock + dynex Best Buy fans. Would swapping them all out for high cfm fans be enough to cure the problem? I would like some opinions before I drop $120 on 6 top of the cfm line fans.
Reply to Klon0pin
Thats what i thought. The stock CM fans are nice and quiet but don't flow worth a ***. I swapped every fan in my CM 690 with the fans below and it runs beautifully.
http://www.newegg.com/Product/Prod [...] 6835185060
Dual 2.8Ghz SL8MA's
16GB DDR2
XFX 5770
What case are you using?
The other issue is my MOBO (asus p6t) has me running sli in 2 pci x16 slots right next to each other unlike most 2 card sli/crossfire setups where you have an empty slot in between the cards.
Reply to Klon0pin
Same case as you are. Coolermaster CM 690. I'm running two 4770's in Xfire so i totally understand the heat issue. Throw in my 4 heat pump raptors and the case got very toasty with the stock fans.
Message edited by PsychoSaysDie on 06-23-2009 at 07:00:18 AM
Dual 2.8Ghz SL8MA's
16GB DDR2
XFX 5770
Download this program from EVGA. The EVGA Precision 1.7.1, which will allow you to control the fan speed and also OC your card if you want to.
Read info of it here.
http://www.evga.com/precision/
Best place to download it is here, since you would have to register to EVGA Forum to download it there.
http://downloads.guru3d.com/EVGA-P [...] -2251.html
Reply to Yoosty
I use Nvidia Control Panel and the temps I'm refering to are at 100% gpu fan speed for both gpu's.
The cards are BFG Maxcore (216 Sp) gtx260's btw. And they are set to factory clock speeds. Overclocking them in SLI gives great fps results but makes the heat problem show up faster.
Reply to Klon0pin
You have no space at all between the 2 cards? Can you give me the spec of your fans? If nothing else works water cooling might be the solution which is a bit costly.
Reply to invisik
get some good TIM and reseat the GPU heatsink with the new TIM.
Reply to Helloworld_98
the cards are practically touching.
@ PsychoSaysDie:
what did you do about your heat? Just upgrade the fans?
Is there watercooling for tri-sli because it's layed out like the top 2 cards in a traditional 3-way sli setup.
Reply to Klon0pin
@ PsychoSaysDie:
Those Upgraded fans and a pair of Duorbs for my video cards. I have zero heat issues.
Message edited by PsychoSaysDie on 06-25-2009 at 04:38:54 PM
Dual 2.8Ghz SL8MA's
16GB DDR2
XFX 5770
There are 779 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
