I have a older gateway and the power supply went south. The old power block is newton model nps-160cb-1 a.
I order a new one from newegg but was sent wrong one. I need 20 pin + 4pin. I was sent a 24pin. I need to ask what one from newegg will work. atx or atx12 and so on. my gateway is model # mfatxpnt esx 500x. thanks for your help!
I have a 24 pin to 20 pin converter connector. I'll send it to you for free, if you email me your name and address. I don't want to post my email, but if you're registered with anandtech, you can pm me under o1die. The software at Tom's has changed, and pm's don't work for me.
Message edited by o1die on 06-23-2009 at 03:42:02 PM
[quotemsg=1948308,2,128]I have a 24 pin to 20 pin converter connector. I'll send it to you for free, if you email me your name and address. I don't want to post my email, but if you're registered with anandtech, you can pm me under o1die. The software at Tom's has changed, and pm's don't work for me.[/quotems
