How do you open the case to get to the fan to clean (or replace) it? Do you take off the front plastic "mask", because I can't see the a way to get to the fan from inside of the case...
Ahhh... from the picture you've shown, it looks like you have to detach the entire front assembly from the case frame. Does the manual say anything about this?
