Yes all Sata ports are enabled and set on AUTO detect.
at the moment I have removed one Sata-1 HDD, and now I have this:
TWO IDE PATA
one master ( bootable active partition with OS ) MAXTOR 40GB
one slave ( no bootable active partition, no OS only Data) SEAGATE 40 GB
ONE SATA -0
Sata-0 HDD seagate 250GB
ONE SATA -1
Sata-1 DVD Writer TSST corp.
Sata ports configured for HDD as AHCI enabled.
BIOS-> Boot priority-> HARD DISK, DVD, Removable.
in this case IDE MAXTOR boots first, then Sata-0.
To forcefully boot from Sata-0, I have to:
1.disable IDE onboard ports from BIOS
OR
2.Mark Boot partition as inactive and hide boot partition on IDE
OR
3.remove IDE cable from both IDE drives.
Only in case of 2. I am able to boot from Sata-0 and still able to see IDE partitions in Sata booted OS.
Suppose I populate this:
IDE HDD master + slave two HDDs , master with bootable active bootable partition.
Sata-0 HDD with bootable partition
Sata-1 HDD with bootable partition
Q. What is the easy way to go , to boot selectively from the drive/partition of my choice between IDE master, Sata-0 and Sata-1 HDDs?
as stated above, If I disable IDE onboard from BIOS, my IDE is still connected and set, no need to open the case to remove any cables. BUT I am unable to see IDE partitions in Sata booted OS.
another thing, suppose IDE is out of question ( assume not installed) now to selectively boot between Sata-0 and Sata-1, ... :
hard crude way: swap the sata-0 and sata-1 cables, since sata-0 HDD will get priority first
but to do this, I have to open the case everytime.
please suggest
