Due to having a mac pro I have to run an external power supply for a gtx 295. I have read that it needs 680 watts to run. Is that including the other computer components altogether or just by itself? I am a little confused cause i also read that it requires 285 watts of board power and I don't know what that is. So what power supply would be sufficent to run this card as a dedicated external source? 450? 750?
The card doesn't require 680 watts to run. The specification is accounting for a full system.
You could try running a dedicate GPU power supply. I believe it requires a connection to your existing power supply via a molex connector (4-pin peripheral)
I don't know the max power draw off the top of my head, but I assure you it is sub 300W. Also, remember that some of that must come through the motherboard (and thus some comes from the non-dedicated PSU). I ran a system like this back when I had my 2900XT and it worked fine (though ravenware is right about the connection to you MB power connector, at least for the one I had).
------------------------------New Build (Under Contruction): Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB > Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > Hyper 212 Plus > See other Builds in Member Config
Reply to EXT64
GTX 295's need 1x6-pin and 1x8-pin. Get a PSU or GPSU that has 2x8-pin or 2x6+2-pin connectors. That or try some 6-pin to 8-pin adapters. They usually work.
I've never been one to use many adapters... I know there are 2-MOLEX to 8-pin PCI-E adapters, like this one. I figured by now someone would have created a single 6-pin PCI-E to single 8-pin PCI-E adapter... Apparently not...
Have you got some un-used 4-pin Molex connectors in that thing to use the adapter I linked? If not, you could spend over $200 on an adequate PSU with all the right cables, or $90 for the more expensive FSP GPSU. At least then you'll be certain to have all the proper connectors you'll need, which are two 6-pin and two 6+2 or 8-pin PCI-E connectors.
Man what I wouldn't give for some industry standards when it came to PSU cabling...
Message edited by RazberyBandit on 04-14-2009 at 05:08:23 AM
Because the one you link only has two 6pins and a weaker output in general. This one http://www.newegg.com/Product/Prod [...] 6817104054 has two 8pins along with two 6pins and has a higher output. Not to mention that one you link is really only 300w. 400w is the peak Its not wise to cut corners on power when it comes to a GTX 295.
Message edited by spathotan on 04-14-2009 at 06:39:28 AM
I have a 285 that needs 2 6 pin, next to a 8800 GT that needs 1 6 pin. I use a Toughpower 1kW external PSU that sits on top of the Mac Pro with several 6 and 8 pin outputs - the latter would be fine for a 295. Bit of a mess arrangement but keeps the power load of the Mac Pro system. My 285 is a big 2G card from Palit and sits in the second PCI-16 slot next to the 8800. There should be room for a 295. My 1kW is totally over the top though......
Im doing something similar but was wondering could the gpu be powered with a 1 powersource on it 6 and 8pin and a different powersource for the mobo and the drives would be split between the 2 im getting these components and i have 2 spare 750watt psu's
i7 920 on a evga x58 mobo with 4 1TB hds and a blue ray drive 12gb ddr3 ram 2 x 750watt ultra brand psu's
possibility of putting a second 295 in in sli at a latter date when a game that can handle it comes out XD
hey guys i am building a huge build
12 gigs of ram
1 tb hd
i7 nehalon or watev 2.66
2x sli 295s
an i7 mobo wiht build in hd sound card
blue ray player
xfi forte sound card
wat shouold my powersupply be (newegg link would be very helpful)
and also, suggestions for a good cheap mobo would help also
