hardware malfunction means some piece of your computer isn't functioning as it should
you want to find exactly which piece is being tagged as faulty, then trouble shoot from there you might have to check the connections and make sure the wires are good or you might need to replace the faulty piece of hardware
we can't help you beyond that with the little information you've provided
