Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > XFX 8800GT Alpha Dog Ed. Extreme Temperature Issue
Forum Graphic & Displays : Graphics Cards - XFX 8800GT Alpha Dog Ed. Extreme Temperature Issue
hi guys, its my first post in tom's hardware forums. guys i m facing a temperature issue with my XFX 800GT ADE Extreme card. its 512MB version and model is "PV-T88P-YDE4". i am using EVGA Precision to set up the Fan speed of card to 100%. the card's temperature stays @ 58C idle, and usually go upto 75C while playing intensive games like Crysis on highest settings. are these temperatures are nominal. as in past i have used XFX 8800GT Alpha dog edition 256MB version. that card was quit and cool one.
i need to know how to lower the temperatures of that card. although card is not showing any anamolies or texture corruptions or any sort of issue. is there any bios upgrade can fix that temperature issue.
Sponsored Links
Yes its normal for a 9800GT, those temps are a bit high tho if you raised the fan 100% just to get them. Have you tried cleaning out the dust from the fans? Also try looking at aftermarket coolers if your interest.
Reply to Axeon
@ Axeon : bro m not talking about 9800GT. what i have is 8800GT. the card is in mint condition, i dont think that any dirt is blocking the air flow in card. where can i find aftermarket coolers for my card.
Reply to predator1983
Shouldnt run that hot. I had the alpha dog 8800GT 256 and the XFX 9800GT 512. The 8800GT ran about 65c on full load, the 9800GT idled at 70c and went to 90c during gaming.
Not sure why your using an EVGA app to change fan speed on an XFX card but I would use Rivatuner.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
FYI 8800GT=9800GT, it is the exact same card.
Yes, your temps are pretty normal for this card, especially being an overclocked edition.
Luckily, GPU's are designed to take quite a bit of heat.
Until you are hitting 90°C+, I would not worry to much about it.
If you really want to lower the temps, look into an aftermarket GPU cooler.
Something like the Artic Cooling Accellero, Thermaltake CL-G0102 or Zalman VF1000 will work great for you.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
There are 549 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
