Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help! second gfx card not recognised by p5n-d
Forum Graphic & Displays : Graphics Cards - Help! second gfx card not recognised by p5n-d
Hi, I have a p5n-d and 2x EN9600GT Silent graphics cards and i can only get one to work. I can't find in any manual a way to enable dual card (this seems to automatically be turned on?). Please let me know if there is a setting somewhere that allows you to switch dual card on (as was the case with my old motherboard). Urgent help needed!!! thanks in advance
Rowan
Sponsored Links
Did you connect the SLI bridge and enable SLI in the drivers?
Reply to gamerk316
hi gamerk316, in the past i haven't needed to connect the bridge (assume this is the goldfinger cable) to get the two cards working. Do i need to for my configuration?
Thanks
Reply to Anonymous
There are 1273 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
