E2160 overclocking help
i am new here. yesterday i overclocked my e2160(250x9=2.25ghz) without change voltage.now my pc runs without problem
but i just know about that it is safe overclocking or i need to increase my vcore too.
my system is
intel e2160 (250x9=2.25)
ecs g31t-m7 mob
2 gb transcend ram
sorry my english is bad plz ignore it
see some pic of cpuz and tell me that my system is stable or not
thanks in advance
More about : e2160 overclocking
CPUs Master
Overclocking Master
if under default Vcore Vdim Core Clock all Stable,
If Overclock must use Software Test Stabillity like Prime95, Orthos, Intelburn test etc,
Don't increase Vcore if u don't get BSOD with massage 0x000000000124 !
Related ressources
yogesh_appu said:
i start this after some time it stop and give me idle message
That means it has finished whatever time you had input correctly. I would recommend having it test for an hour. If it passes than it is stable
Ask the community
