If my system hangs but my dvd drives can still open/close, my casing fans are still running and the keyboard will still light up when I press num lock etc, what is the issue?
To be exact, when my system hangs, ALL usb ports will have no power. Eg, my mouse will not have any light and my thumb drive will not have any light. But everything else including my PS2 keyboard, my casing fans, my dvdrw and my processor fans are all working.
does this means its the PSU problem?
Message edited by elleumas on 06-25-2009 at 05:59:04 PM
I noticed that to be exact, when my system hanged, ALL usb ports have no power. Eg, my mouse has no light, my thumb drive has no light. But everything else including my PS2 keyboard, my casing fans, my dvdrw drive and my processor fans are all working.
I do not think its a PSU problem as this will either cause instant blackout/shutdown, not just hang. I was told it might be a USB problem with my mobo or maybe something to do with the casing.
I will probably try to run the bare setup outside my casing to see if it works
We will need to know all the components of your system to give more specific suggestions. Check and reseat your power connections. This sounds like a +5V rail problem, so it might be the PSU. What brand and model is it?
