Tom's Hardware > Forum > CPU & Components > Other Components > DVI to VGA through KVM Switch Problem
Forum CPU & Components : Other Components - DVI to VGA through KVM Switch Problem
I have a new pc that only has DVI outs on the video card. I use a Belkin KVM and my old PC, a laptop, has VGA out and my monitor has a VGA in. Using the DVI to VGA adapter that came with my Geforce GTS250 video card, I get no video through the KVM from my new PC, but when I hook it up directly to the monitor(bypass the switch), it works. I'm assuming I need a new KVM? Not sure which one though as I need to connect it to a monitor with a VGA input, a PC with VGA out, and a PC with DVI out.
Sponsored Links
Thinking of no other solution, here's what I've come up with:
Hey bmanfeeb, how old is your KVM? Your right to assume that your switch is not processing the signal from your desktop properly, and you may need a newer model that properly interprets converted signals from a DVI port.
Look through NewEgg for something that has a better rating than your current KVM.
Reply to Lavarin
- 0 +
I have a 7 year old 4 port Cybex Switchview has no problem with a DVI/VGA adapter.
Do you have the little 2 port Belkin switch? If so, it's strange that it will not work with an adapter.
Reply to jsc
Thanks for the responses!
My KVM is about a year old and it is the 2 port Belkin Model#F1DK102P.
I'm thinking about going with an IOGear GCS22u because it's cheap and I don't want to spend to much just to find out it won't work either. It has 5 eggs on NewEgg. What do you think?
Reply to bmanfeeb
I have a Trendnet KVM with VGA port only and all my new PC have DVI.
I use the VGA/DVI adapter with no problem.
I have a 4 ports, 6-7 years old KVM.
http://www.trendnet.com/langen/pro [...] 0K&cat=105
------------------------------ http://valid.canardpc.com/cache/banner/476621.png
Reply to nocteratus
Well, I'm guessing something must've been wrong with my Belkin. I went out and got an IOGear GCS42UW6 and it works fine. Thanks again for the feedback.
Reply to bmanfeeb
There are 1222 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
