G
Guest
Guest
Hi everyone. Maybe it's not overclocking problem, but I couldn't find a section that would fit better.
I have a computer with MSI 770 C45, AMD Phenom X4 955 BE (not overclocked!) with Scythe Mugen 2 rev. 2 cooler in Cooler Master Elite 330 case. I have some huge problems with CPU temperature.
When idle Everest shows me a 46*-52* (~118-124 *F) celsius. Yesterday when I started Prime95 stress test in few (3-5) seconds the temperature rised to 66 (~150 *F) degrees so I stopped the test.
Today when I dismantled the whole PC I noticed that radiator left only a little mark on the CPU paste (Arctic Silver 5). You can see It on this picture
http://yfrog.com/0isnc00875j
So the central section of CPU is not covered by radiator. I tried to install cooler in different positions, but unfortunetly there is no which fits good.
I put more thermal paste on cpu and radiator than before to fill the empty place (but not too much, just a dot in size of one - two rice grains). Now its just a little bit better. In Prime95 stress test CPU reaches 63 celsius degrees in 2 minutes (when third test starts), but still its way too much! I know that CPU can work in so high temperatures (although AMD website info says that 62 is a maximum temperature), but I dont want to. I payed for decent cooling and good case to have low temperature CPU. I don't need another heater in my room.
Do You have any ideas how to help me? What can I do to make the cooler radiator cover the whole CPU?
Thank you in advance for any suggestions. Im fighting with that problem for one week and I'm now desperate. Sorry for my English, I haven't used it for long long time.
PS There is a good air circulation in the case. I have two 120mm x 120mm fans (one in the front, second in behind), and a huge fan installed in PSU (OCz ModXStream Pro 500W). When the cover is opened I have only 2-3 degrees lower than when its closed.
Also before I had standard box cooler, after that I only rubbed the old thermal paste (I think it was also standard OEM paste) with just a tissue.
