Guys Iwant to buy a arctic cooler freezer 7 pro for my 865gvm3v lga 775 mobo.
Actually my stock cooler for Intel p4 (prescott socket 775 lga) not working properly I guess....as I opened the heat sink from CPU and done somethng wrong with the thermal pase(It was almost dust may be a bit of it blown away)....and now whenever I try to run photoshop cs3 / illustrator cs2 & even for no reason my PC just keep restarting for 4 - 6 time in a row.
As a result I have to switchoff the UPS for almost 2-5 hrs or even for a day....
that is why i'm going to buy the arctic cooler........
AC Freezer7 Pro is a good choice and easy to use since it has the thermal compound pre-applied on the heatsink.
You'll want to make sure your CPU heat spreader has been cleaned.
CoolerMaster Hyper TX2 is a close competitor of the F7P in the same 92mm fan size cooler group. It's about $20 and free shipping @ NewEgg.
Thanks once again I will search for all of your suggessions but the problem is I'm from India (kolkata) so it will be not so easy for me to find out these all ANY GOOD ONLINE STORE SUGGESSION??......however HOW TO CLEAN THE CPU HEAT SPREADER..wit which material.? I am asking because I didn't do this before ...& at present I'm typing thiswhile my computer is running in safe mode otherwise it won't boot
My case is a frontech mini tower type case though it has a extra fan on left side & a similar vent on right....the space inside t is very narrow I will post some pix later.
