Gtx 260 power
Ahhmmogh
Hi , I just built my computer and have everything running , but the only problem is when I unplug the power of the graphics card , I have a display , everything runs perfectly. The moment I shut off the computer and plug in the 2 6 pins for the gtx 260 and try to power my computer , nothing. I have no display whatsoever
but the graphics cards fan is running. I have a 550 watt power supply , that seems fine please help
answers
Last reply
More about power
Motherboard - GIGABYTE GA-MA74GM-S2 AM2+/AM2 AMD 740G Micro ATX AMD Motherboard
heres link - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128342
CPU - AMD Athlon 64 X2 7750 Kuma 2.7GHz Socket AM2+ 95W Dual-Core black edition Processor Model
link - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103300
Ram- G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
link - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
and power supply
Rosewill RP550-2 550W ATX12V v2.01 Power Supply
link - http://www.newegg.com/Product/Product.aspx?Item=N82E16817182017 -
Well considering it can power a 4870 which uses more power then a 260...you should be fine
Albeit if you haven't bought the psu yet you should do as i did and spend the extra $ on the corsair 550w
I spent around 20$ more after rebate and i had seriously been eyeing that rosewill due to it being such a low price...meh i went with corsair for the peace of mind
Unfortunately it was DOA and iv sent it back...anyways yeah you should be fine with the rosewill...nice build btw
How much will you have in your build after tax/shipping?
Graphics Cards
Computer
Power
Graphics
Product
Related Resources
- Power on Delay
- Would I be able to use this graphics card in my computer
- Graphics cards and power requirements?
- Low Power Graphics Card
- 650watt Power Supply Won't Power EVGA ATX 460 Graphics Card
- Two power supplies to two graphics cards
- Power Supply and Graphics
- Best Graphics Card for 300 Watt Power Supply
- Graphics card with 250W power supply?
- Computer won't start with pic-e power connected
- New graphics card with a 500w 12v 22A power supply
- Graphics card causes computer to shutdown
- Power Supply, Help
- No Power for My Graphics Card!
- Using too low of a power supply in a computer
- My Computer is eating power supplies
- New graphics card and power supply
- What graphics card would fit this computer? And what power supply?
- Graphics Card - No Adapter from Power Supply
- Recommended power supply for amd 6670 hd graphics card ddr5
