Tom's Hardware > Forum > Homebuilt Systems > New System Build > System boots, keyboard doesn't work past BIOS
Forum Homebuilt Systems : New System Build - System boots, keyboard doesn't work past BIOS
I just build a new computer out of all new components (with the exception of my hard drives and my DVD drive). My new motherboard does not have PS2 ports so I have to use the USB mouse and keyboard which worked fine with the previous set-up I had with the same hard drives.
The keyboard works fine in BIOS, but once Windows loads I lose power to the keyboard (the num lock lights don't light up and I can't type). I have USB and Legacy enabled in the BIOS, but I did not see anything about enabling a USB keyboard like some other forums suggested.
What can I do?
Sponsored Links
After windows boots, unplug then replug the keyboard. Or try in another USB port. If nothing else I suggest a new keyboard.
Reply to IH8U
Motherboard please, so someone can look through the Bios for you.
Reply to knotknut
I've tried two different keyboards. The one I had previously been using (which was wireless) and a regular keyboard with a cord. Both USB. Neither worked, I tried different ports and replugging in after BIOS, both had the same result of only being functional in BIOS.
My new motherboard is an Intel DP35DP.
Reply to Anonymous
There are 802 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
