Tom's Hardware > Forum > CPU & Components > CPUs > AMD Phenom II X4 955 BE. multiplier and Core Volt problem
Forum CPU & Components : CPUs - AMD Phenom II X4 955 BE. multiplier and Core Volt problem
hi guys im using AMD Phenom II X4 955 BE.
with motherboard ASUS M4A79 Deluxe. BIOS updeated to version 1702 (latest)
my 'COOL N QUITE' is disabled in BIOS
and power scheme in Vista 32bits set to high performance.
i even set my multiplier and voltage in BIOS as X16 and 1.35 voltage
however, CPU-Z shows me unstable multiplier with unstable core VID
multiplier change X16 to X4 frequently and core VID change from 1.35 V to 0.975V frequently as well.
please give me a solution for this!
ill appreciate any of your thoughts thank you!
Sponsored Links
I suspect that's just the CPU going to lower-power states when the load is low. This should not affect performance at all, so it should not need a "solution."
------------------------------ e2160@3GHz: OCing my way to Ubuntuland!
Reply to Mondoman
If you go into power settings and the advanced settings under high performance click on change settings, than click on change advanced power settings. A new window will pop up and you should be able to scroll down to Processor Power Management, varify that both minimum and maximum processor state are set to 100%.
Reply to loneninja
There are 1206 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
