Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Substantial difference between 4870 512MB and 1GB for my system?
Forum Graphic & Displays : Graphics Cards - Substantial difference between 4870 512MB and 1GB for my system?
Hi, I've decided to get a 4870 for my computer, but I'm wondering if there will be a substantial benefit to the 1GB rather than the 512MB for my system. Also, if anyone has recommendations for brands it would be much appreciated :)
One final question, what is the difference between HD and AX?
Intel Core 2 Duo E7200 @ 2.53 GHz
4GB RAM
500/650 PSU (not sure which one im getting yet)
1440x900 resolution
Sponsored Links
Have you checked out any of the benchmarks between the 1gb vs 512mb on different resolutions etc? :ange: Of course not....no one does...
You will be fine with the 512mb aslong as you don't try upgrading your monitor past 1440x900....if you plan on uping your resolution anytime soon go with the 1gb...
Message quoted 1 times
Message edited by rewindlabs on 04-17-2009 at 08:16:55 AM
------------------------------ http://i151.photobucket.com/albums/s145/RSSRM/ay14s5-1.jpg
Reply to rewindlabs
Sorry, I'm not really computer savvy and didn't think to do that :(
I checked them out though, seems like a negligible difference.
Reply to Paladuck
There will be NO difference for you at the resolution of your current monitor...so if your going to stick with that monitor's resolution the 512mb version will be more then enough...great prices on such a powerful card atm to....
Reply to rewindlabs
For ~20 dollars difference, why not go for it just in case your monitor dies and you end up replacing it with a higher resolution one? Or if you replace it on your own or receive one as a gift later, or even decide to try hooking it up to a LCD or Plasma TV with higher resolution? In any of those cases, performance on the 512MB will begin to suffer, whereas it wouldn't w/ the 1GB version.
Yes, the 512MB version suits you great right now, but if there's any chance anything like what I mentioned above happens, ~20 bucks gives you some peace of mind.
Message edited by RazberyBandit on 04-17-2009 at 10:27:59 AM
Reply to RazberyBandit
+ 1, $20 more gives you freedom to upgrade plus its a good deal. Double the mem. for only 20.
Reply to AKM880
Well, in some cases it could be more than $50 difference, but the jump from the absolute cheapest 512MB to the cheapest 1GB on Newegg is like 20 or 25 bucks. To me, it's worth it.
+1 for the 1GB 4870...The price difference is very less and having a 1GB card would handle the higher resolutions well...
Reply to gkay09
Spend a $100 on an HD 4850 (after rebate and if you are in the US)
http://www.newegg.com/Product/Prod [...] 6814121272
At your resolution and with your CPU at its current speed you won't notice much of a difference between it and an HD 4870.
As far as HD 4870s go there is little to no difference in performance until you pass 1680x1050 resolution. A 1GB card is definitely not necessary on a 19" widescreen. If you don't plan on a monitor upgrade any time soon go for whats cheapest (if your set on that GPU).
Message edited by jeffredo on 04-17-2009 at 06:55:35 PM
Reply to jeffredo
There are 583 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
