Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > RAM vs Motherboard: Which is the problem?
Forum Motherboards & Memory : General Motherboard - RAM vs Motherboard: Which is the problem?
Hi guys here is my rather old setup:
- ASUS A8N SLI Premium S939
- AMD X2 3800+ 2.0 Ghz (OCed to 2.3 Ghz)
- Acer 8800 GT 512 mb
- 2 GB of DDR 400 Kingston
- Enermax 460 Watt Power Supply
- Windows XP Pro X64
I have been playing Crysis online for couple of months and suddenly one day, the game started to BSOD crash... After reboot, the game kept crashing. So I went and read the forum and found that people with 8800 gt and 9800 gt have the same issue. I followed the advice and performed the followings:
1) I removed the nVidia drivers 190.xx which I had installed around June and Reinstalled the latest. The problem was NOT solved, so:
2) I got a can of dried air canister and tried to removed the dust from my graphic card and RAM ... Again, problem was present.
Next, when I was browsing the web, the system suddenly gave me a BSOD. So I decided to first reinstall windows and then check the RAMs... which was a big mistake because I was impatient... So I formatted one of my partitions and tried to re-install the O/S . However, after going through the setup and formatting and installing initial files and reboot... the system gave me an error along these lines: Wrong Hard disk configuration. Which is BS because I have formatted and installed O/S many times on the same configuration... I ve built this computer myself.
So now, I cannot install, so I started to check the RAMs individually. I have 4 x 512 mb DDR 400 Kingston memories. So I planned to remove all of my RAMs and try to plug them back and run the installation process on 512mb of memory at a time:
For the first RAM, after reformatting and reinstalling, I got the same error...
So i tried the second RAM stick, except as soon as I put it in and turned the computer on, it started to smoke! so immediately shut the main power button on Power supply (less than 1.5 sec)
After that, I tried to check other RAMs and again, the installation did not work... So, please advise me what to do?
Im sure i have destroyed that second RAM but not so sure about my main board :S
HELP!
Message edited by Parsian on 09-11-2009 at 06:05:29 AM
Sponsored Links
What was the voltage of the RAM?
Could be a bad power supply.
Reply to evongugg
im not sure, but I never actually played around with my RAM.
Reply to Parsian
You may have a bad power supply or a short to the motherboard.
Reply to evongugg
Hmm the powersupply seems fine, i hooked it up to another system and been runing for a while with no issues
Reply to Parsian
This is what i get during the BSOD:
*** STOP:0x0000003b (0x00000000C0000005, 0xFFFFF97FFD0763C, 0xFFFFFADF81182E10, 0x0000000000000000)
*** nv4_disp.dll - Address FFFF97FFD0E763C base at FFFFF97FFD028000, DateStamp 4ac0055d
Reply to Parsian
There are 1105 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
