keith808 :
okay the notua is huge.. thas why i kinda want to avoid getting it.. but yea.. what about 2 fans on the 212? would that make a differance
The 2nd fan on the CMH212+ at the most will improve performance by 1c, been there done that, but you can still go that route and find out for yourself.
I would suggest not just going with a 2nd fan but replacing the existing and going to higher cfm fans period, say around 110cfm fans a 120mm matched pair, that is, if you want to improve on what you already own.
The higher cfm fans will gain you about 3c under load which is actually not that great of an improvement, but could keep you just inside the ballpark.
If you want better cooling it's going to cost you more, you really do get what you pay for when it comes to air cooling, and if it would fit in your case I'll 2nd luke904's Noctua suggestion.
But regarding your original question, why don't you try overclocking first, and then see where you stand as to your cooling situation?
