Im buying a new motherboard its for an I7 system and dont know if there is much differance btw the GA-EX58-UD3R www.newegg.com/Product/Product.asp [...] -EX58-UD3R and the GA-EX58-UD4P www.newegg.com/Product/Product.asp [...] -ex58-ud4p i know that the ud4p has more memmory ram slots and one more pci ex i will only be sliing with 2 cards so i want to know is that the onl differance and also is this good for overclocking and i will not be buying the asus ones so dont comment uy the asus p6t or somthing
eSATA: UD4P = 2, UD3R = 0
PCIe: UD4P = 2@16-16 or 3@16-8-8, Ud3R = 2@16-16
Audio: UD4P has a different audio chip, I didn't bother to look it up. You can.
COM port: UD4P = 0, UD3R = 1
Construction: UD4P has "more" features
Memory: UD4P supports faster mem speeds than UD3R, UD3R supports faster speeds than you will use.
Message edited by Twoboxer on 06-30-2009 at 10:00:05 PM
