Power Supply Upgrade
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply Upgrade
Is it possible for me to upgrade the psu in my current computer with an aftermarket product?
I'm currently using a Dell XPS420 with L375P-00 power supply, aka. the Dell 375 watt power supply.
I want to upgrade my power supply to one with at least 500+ watts in order to have the required power to support more powerful graphics cards, since I use the computer for avid gaming.
I've been looking at name brand PSUs with alot of power like this one:
http://www.newegg.com/Product/Prod [...] sair%20750
Unfortunately, I'm not able to figure out what psus would be compatible with my setup and fit correctly in the case. I have heard something about certain dell model's being proprietary so that you can only use their psus?
Sponsored Links
I guess this PSU is the best bet...
PC Power & Cooling Silencer Dell Upgrade PPCS500D 500W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
10% off w/ promo code "psu10saving”, ends 6/30
http://www.newegg.com/Product/Prod [...] 6817703016
Reply to gkay09
- 0 +
i have looked on the web and it says that a standard powersupply will fit in your case-
check the measurements though as dells are fussy on size
Reply to Hellboy
Dell psu's are proprietary (ie, needlessly different than standard), as are many other of their parts including anything that connects to the case front panel.
Here is one solution:
http://www.pcpower.com/products/de [...] index.html
Another rather messy solution that might work is to use a second power supply. You'd have to mount it perhaps on top of the case, establish a common ground, and extend the wires for (eg) auxilliary vid card power into the case.
Reply to Twoboxer
- 0 +
some are, some are not
the xps does user a normal atx 24pin / 4 cpu pin psu
Reply to Hellboy
- 0 +
I thought that Dell got away from proprietary PSU's (nonstandard power connectors) in the last few years.
Reply to jsc
- 0 +
There are certain Dell PIII/P4 systems that use proprietary PSUs, but anything modern is ATX standard.
------------------------------ http://farm4.static.flickr.com/3073/2578392638_2827857d10_o.png
Reply to B-Unit
- 0 +
Thanks for the info!
Reply to Devinci
Then I guess PCP&C listing the XPS420 as compatible with its Dell-format psu is a mistake?
Reply to Twoboxer
- 0 +
Its a way of selling more.
Also some psus have the power connectors up tight so they wont fit comfortably but wiring internally are the same - depends if you can get a cable round the fancy cable management systems.
Reply to Hellboy
Really? They sell one line of Dell replacement psu's. They are either wired for Dell, or they are not.
Which is it?
Reply to Twoboxer
- 0 +
The current psu has the atx 24-pin power connector connected to the motherboard, and the corsair psu's specs seem to show that it has everything I need in terms of connectors, however I'm not sure how proprietary the case itself is, and if it would fit in the case properly, or at least manage to with some tweaking or something to hold it in place.
Reply to Devinci
Dell got away from using "special" PSUs when the P4 came out. Their current lineup all use standard ATX PSUs, at least electrically. I'm not sure if they still use some none standard form factors.
The Dell 375W is a rather powerful PSU. It has 30A on the two 12V rails. What are you trying to run that takes more power? You probably can't run the GTX cards, but the GTS and lower should all work. (You'd be cutting it close with the GTS250/9800GTX+)
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
- 0 +
I'm going to possibly be purchasing a 260gtx or price equivalent ati radeon.
Reply to Devinci
The 4770 of course will run in there with ease. I can't remember at the moment if the 4850/4870 need more then 30A. Even if they need 30A, you have exactly 30A available, so you should upgrade. Find a normal ATX PSU and make sure it fits, and watch out for those longer ATX PSUs. I think the longer ones are primarily 1kW and above, so you probably won't see any in the 500-650W range.
Always a DEMON!
Reply to 4745454b
- 0 +
You need a new case... or a lot of patience and a good Dremel if you want to put generic hardware in your... SPECIALLY DESIGNED... computer. The dimensions are all custom made for Dell hardware.
I know it personally, I have dealt with it for a customer >:P
Reply to redgarl
^+1... Oh dear, another user finding out that Dell didn't want you to do anything to your PC when its time to upgrade, they want you to buy another one!
Of the few Dells i've seen inside all are a pain in the a$$. They mount their stupid proprietory mobos with non-standard panel connectors on the other side of the case - I was helping a mate fit a new GFX card to his Dimension and we had to take the 2 slot backplate off the card and saw it in half so we could get it in!! Their PSUs have odd length cables to fit their wonderful custom cases, you'd probably be ok putting a std PSU in, but you'll probably have to drill new holes to screw it in and the PCIE power for example probably wouldn't be long enough to go round the way Dell wanted it too!
It can be done, although as a hater of Dells I'd be tempted to get a new case and mobo and throw the Dell stuff away!
*Don't buy Dell!*
Reply to MMclachlan
redgarl wrote :
You need a new case
No he doesn't.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to DellUser1
You're right on some of it, but there's no need to drill any holes.
Reply to DellUser1
Quote :
You went through all that instead of buying the proper half height video card? Weird.
Always a DEMON!
Reply to 4745454b
4745454b wrote :
Quote :
Sounds more like he fit a dual slot card into a mBTX system.
Reply to DellUser1
- 0 +
I get the same, i went to a customer today who thought downloading the free edition of AVG is better than the purchased version from Kaspersky.
Reply to Hellboy
This is why I always ask people to qualify better. Free AVG is better then paid Kaspersky as it costs less. See, its better. If you mean better as in virus detection and removal, that belongs to Kaspersky. You can't just say better.
Always a DEMON!
Reply to 4745454b
- 0 +
I know,
He was a cocky 20 something. thought he was flash buying his boss a mcdonalds
I just looked at him for a second with no expression and ignored him
Sorted the server issue and got out as quick as i did.
The best bit is 2 of the problems were so called recalls.
the first - someone removed the pc from a setup which used a kvm and wondered why it didnt work
second - the twit installed nero twice and wondered why his dvd drive we missing - he screwed his dvd upper and lower filters (xp)
then the bright spark jumped up mmm machines got xphome on
i mean duh
Reply to Hellboy
- 0 +
Thanks again to everyone who provided me with information, tips, warnings, and advice in general with my issue. I wanted to dig this thread back up to let you know that I was successfully able to install the corsair tx750w power supply into my dell xps 420 without picking up a drill.
The only con I can think of is that I didn't purchase modular, and have 3-4 cables that I am not using at all cluttering up the case, but I wanted to save some cash.
After measuring my own psu and seeing the mechanical drawing of the 750
I though that it would fit, but might be slightly longer in the case (which is a nonissue).
The holes where the previous psu were screwed lined up properly, and everything worked out.
Thanks again for helping a noob out.
Reply to Devinci
No problem, and thanks for the feed back. Perhaps now the non believers will accept that Dell has gone to normal ATX PSUs, both physically and electrically. I would still double check, but things should be fine now.
Always a DEMON!
Reply to 4745454b
[i][/i] Ok everyone here is the deal i have a dell xps 420 also its about a year old i have a masters in computer tech and a masters in computer programing if u have a intel quad core or a intel quad core exstram in your xps tower the tower can take up to a 1200 watt power supply my xps 420 has a newly installed Antec Truepower Quattro 1000 watt power supply my tower works great dell has there heads up there ass you can go as high as a 1200 watt power supply make sure the power supply u buy has a 24 pin main power connector and a 4 pin back connector and it wont hert the tower or motherboard dell told me same thing about only being able to take up to 470 watt power supply but a computer tech knows more then a buntch of ppl at a corperation that is based out of india. so also if u want info on video cards a intel quad core 2.40 gh board can handle 2 2gb video cards a intel quad core extream can handle up to 4 2gb video cards with crossfire support. hope that helps you all :hello: :D
Reply to AntonioMichael
- 0 +
Hmm, apparently no where in all that schooling were you required to take any English courses.
Sad for us...
Reply to B-Unit
*** ing *** ing talking your ***
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply Upgrade
There are 847 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
