Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How to figure out how many watts is enough for your power supply?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - How to figure out how many watts is enough for your power supply?
I just ordered parts to put together a good fast system. I ordered a 750w power supply and am wondering if it is enough.
If you want to know exactly what I'll be running off of it, it is listed here: http://www.tomshardware.com/forum/ [...] 0#t1955537
But I'd like to know the forumla for figuring it out for other systems I build too.
thansk!!
Sponsored Links
Drop the Rosewill PSU, from the look of things a good quality 650W will be more than enough. Look for: Antec, BFG, Corsair, PC P&C, OCZ, or Silverstone (unless in a 220v area).
Reply to IH8U
Why do people ask after they've already ordered? I don't understand that logic.
Reply to Devastator_uk
That particular Rosewill is a new one; 80+ bronze certified, with Active PFC. While the older Rosewills were lessons in overrated suckage, that new model should be decent. At the very least, it was run at 100% during the certification process, and didn't croak.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
I was considering going with this one: http://www.newegg.com/Product/Prod [...] 6817182188
The reason I'm 2nd guessing my purchase in the first place is a guy who works with me says if I add a 2nd graphics card, the power supply probably will not cut it.
Reply to developermct
Thanks for your input guys!
I found this article and shed some light on the topic for me: http://www.anandtech.com/casecooli [...] i=3413&p=1
This PSU is better quality and plenty of power for 2 4870s.
http://www.newegg.com/Product/Prod [...] 6817139010
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | 2x GTX260 216
Reply to theAnimal
There are 1348 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
