Archived from groups: alt.satellite.tv (More info?)
I have a Dish Network 522 dual-band receiver, and the 2nd remote, a UHF
unit, doesn't work very well. It is sensive to the exact location it is
transmitting from (one foot to the right or left affects the signal).
Dish has already troubleshooted this thing to death, and can't find a fix.
Has anyone else experience problems with the #2 UHF remote?
"Robert A" <LA_Native@hotmail.com> wrote in message
news:9tSdnev_X6LUGTfcRVn-3g@adelphia.com...
> Robert A
Yes! I have very similar problems...my 522 receiver is directly below the
living room in the basement -- not like it's located very far from where I'm
using the UHF remote.
The 2nd UHF remote won't work when it's close to a human...I have to hold it
out a bit to make it work. Or I have to point it up at the ceiling...if I
point it at the TV (which there's no reason to do so...just old habit) then
atleast half the time it won't work. Combine this with the delays of sat TV
channel switching (I have a 2-dish, 3-sat setup with DISH), this becomes
very frustrating. I plan on calling DISH today.
Please follow-up with any information you find. Thanks.
It's a radio frequency based remote. I have the same issue and just shift
it and get connected.
there's nothing to troubleshoot.
> Robert A
Hello:
I had the same issue. I solved it by running a coax cable from
the 522 to the back of the house where the other TV's are located, and
putting the little UHF remote antenna at the end of this coax. The
idea is to get the UHF remote antenna closer to the remote
transmitter. This solved all of my UHF remote problems.
In my case I had existing coax in the wall from the old cable tv
installation, so it was trivial.
Larry
On Wed, 05 Jan 2005 05:26:53 GMT, "jacklightner" <toddwil@hotmail.com>
>> Robert A
