Hey guys. I had a question for my i7 system. I do not have a NIC card and am still using a lousy USB wireless adapter. I'm looking to upgrade as I play a lot of games, specifically wow and I think I want a stronger connection. Would it be better to just get a NIC and get the router and etc. moved to my room, or would it be easier to get a real wireless internal card? And if you can could you suggest a certain NIC or Internal card from newegg or something?
Thanks
Sponsored Links
What system or motherboard do you have? I've never seen a Core i7 motherboard that doesn't include at least one on-board NIC.
Reply to GhislainG
I have the gigabyte GA-EX58-UD5. So no opinions on the wireless card? Not sure if I really want to move the routers as I'm on one end of the house and it could hurt the people on the other side. THe router is currently pretty much directly in the middle of the house.
------------------------------ | GA-EX58-UD5 | i7 920 | EVGA GTX 260 Core 216 896 MB | OCZ Gold (3 x 2GB) | Western Digital Caviar Black 1TB 7200 RPM | Corsair 850W | Antec 1200 |
Reply to ryankn852
- 0 +
What router are you using "B", "G", or "N"?
Any way you can run a Cat5 cable from the router to your computer?
Wired is almost always better for games.
Message edited by lyleb on 07-25-2009 at 08:48:11 PM
Reply to lyleb
Look at Cisco or Linksys, but a good wireless card won't solve the problem if you use a cheap router. Running a Cat5 cable and connecting directly to the router always works better (gaming or not).
Reply to GhislainG
Tom's Hardware > Forum > General Networking > Network General Discussions > I7 System - Nic or Wireless
There are 1090 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
