Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > [Solved] Problem help somebody
Forum Motherboards & Memory : General Motherboard - [Solved] Problem help somebody
Best answer from jsc.
i have problem with my RAM and MAINBOARD
right now i use the
intel Q8200 clock @ 2.8ghz
PSU cooler master 1000 w
RAM HYPER X 1066 mz
mainboard EP45-UD3P gigabyte.
Grafic Card HD4870
the problem is i can clock to 3.4 ghz but when i use value ram kingstone & appcer i can pull to 3.4 ghz
please somebody there help me with hyper x only 2.8,i use in bios or the easy tune 6 also fail
Depending on a lot of factors (stepping, VID, case, cooling), upper range of Q6600 is 3.4 GHz to (rarely) 3.8 GHz.
You are hitting 3.4 GHz. with a Q8200. The system architectural improvements of the Q8200 will just about balance out any potentially higher speed of the Q6600.
If you have a Q6600 lying around, you can try it, but it's not worth buying one.
Sponsored Links
is your problem that your hyperX ddr2 is holding back your overclock?
If so then turn down the memory-FSB clock ratio. You are probably trying to clock your memory too high, or alternatively, turn up the voltage on the memory (this might void your warrantee though)
If that's not the problem, then you have run into a problem with the Q8200. The Q8xxx series processors are notorious for not being good overclockers, because of their low multipliers and high stock FSBs. You can't really get them to clock that high because you'll hit the maximum FSB clock and the multiplier doesn't get you that far. If this is the case, sorry but you can't do anything about it.
------------------------------ Core i7 920 @ 4GHz under a lapped TRUE, EVGA X58 3xSLI, Three EVGA GTX 260/c.216 in Tri-SLI, Corsair Dominator 6GB DDR3 1600, Intel X25-M 80GB ssd, WD Caviar Black 1TB, Caviar SE 640GB, Silverstone Decathlon 1000W PSU, Lian-Li Armorsuit PC-P60
Reply to tehHooligan
thank for the tips,i agree with your opinion, what your opinion about CPU, if i use the Q6600?
Reply to mezal1981
Best answer
Reply to jsc
There are 1028 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
