Tom's Hardware > Forum > Home Theatre > Satellite TV > How to combine DirecTV, Comcast Cable and Off-Air-Antenna ..
Forum Home Theatre : Satellite TV - How to combine DirecTV, Comcast Cable and Off-Air-Antenna ..
Archived from groups: alt.dss,alt.satellite.tv,alt.dss.tech,rec.video.satellite.dbs (More info?)
Hello,
Can anyone help me determine how to fix this. I currently have a dual
LNB DirecTV satellite that has 3 cables coming into my house. Outside
of my house, these 3 cables are joined with comcast cable using
diplexers. I also have diplexers in each of the 3 rooms to separate
these 2 signals for my DirecTv receivers. This works just fine.
However, I am wanting to upgrade to DirecTv HDTV and also get the HD
local TV channels.
I want to know exactly what I need to buy. I know I need an HD
receiver. I know I also need the Off-Air-Antenna to get the HD local
channels. Do I need a multiswitch??? Triple LNB?
Once I have everything, I need to know how to combine DirecTv, Comcast
cable and the Off-Air HD channels with only 3 cables coming into my
house.
Thanks!
Sponsored Links
On 30 Nov 2004 19:28:57 -0800, robmking@sprintpcs.com (King) wrote:
>Hello,
>local TV channels.
>house.
>Thanks!
Right now you're using diplexers to split off the combine cable and
SAT signal. Why don't you just run a separate coax for the off-air
antenna to your HD receiver? Depending on your signal quality you may
need to do this anyway especially if you have to amplify this signal.
Greg
Reply to Greg
- 0 +
I use a roof antenna for HDTV local and found that a separate cable run
worked the best.
Diplexer got in the way of the signal. I know it is not supposed to but it
did.
"King" <robmking@sprintpcs.com> wrote in message
news:37c4478.0411301928.472af352@posting.google.com...
> Hello,
> local TV channels.
> house.
> Thanks!
Reply to Emil
- 0 +
Excellent posts!! I'm in the same position and decided to run a separate coax from my roof antenna to my digital tv. Thanks!!!
Reply to Big Al
There are 1118 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
