Tom's Hardware > Forum > CPU & Components > Sound Cards > Asus Xonar D2X problem
Forum CPU & Components : Sound Cards - Asus Xonar D2X problem
hello..
i just bought asus Xonar d2x..the problem is, when i use it, the max volume is very2 slow when compared to the mobo soundcard..i already set up all the volume available to max, but still the volume is very slow...
anyone know what is the problem?
i'm using :
Asus P6T Deluxe V2 mobo
Asus Xonar D2X 7.1
GeForce GTX 285 x 2 SLi
Message edited by dauf on 07-01-2009 at 02:17:23 PM
Sponsored Links
in the back of the card their is a 4 pin plug, is the same plug you use for the floppy disk , you have to connect the 4 pin plug to bring the volume up to work
Reply to jahpal
- 0 +
ow..thanks for the reply jahpal..i'll tey to check it..
Reply to dauf
There are 900 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
