Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will a 200 Watt Pico-PSU Work for this build?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will a 200 Watt Pico-PSU Work for this build?
I'm fairly certain I need something higher,but for my build, I need the power supply to be external, so I have 2 options.
1. Pico-PSU and a Power Brick. The site dosent seem to have a power brick that could power the Pico PSU tho
2. Use a "True" modular power supply and let it sit beside the case (True meaning the main cables disconnect as well).
The first option is much cleaner and nicer,but I fear it wont give me enough power (200 watts is the highest I seen for these).
Anyway,the build includes
Zotac Geforce 9300 Mini-ITX Mobo
Pentium Dual Core E6300
Low Profile Radeon 4650
I used that one power supply calculator ( http://extreme.outervision.com/PSUEngine ),and I got around 150 watts for my system (it dosent list the 4650,so I averaged a 4550 and 4670),so would it be safe to use a 200 watt PS?
Sponsored Links
The PSU calculator gives recommended PSU size, you should be fine.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
You would probably be o.k, but likely it's pushing it. The power draw of the 4650 is closer to that of the 4670. The onboard video of the 9300 chipset isn't bad as it's more powerful than the 3200/3300 on AMD chipsets, so you may just want to use that instead.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
I dont really want to get into too many details of my build, but my goal is to play Halo 2 Vista at higher settings, which the 4650 should do. Since its older game,do you think I could get away with using a lower powered GPU instead?
Reply to teeth_03
look at the silverstone Sugo mini-ITX case, it has a 300w silverstone PSU so you'd get a Q9550 and a 4770 in there with room to spare.
Reply to Helloworld_98
thanx,but im not using an ordinary case
I might just end up going with the modular power supply after all
Reply to teeth_03
There are 1091 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
