Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > VOLTAGE AND TEMP NOOOOOB HELP!!!!!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - VOLTAGE AND TEMP NOOOOOB HELP!!!!!
Hey guys
Well i got my new replacement PSU today. and i think all is well.
well i looked in the bios and it said that the +5.0v was running at 5.2V, is this normal? and does it pose any threat?
here is a screen print of my comp at idle. using HWmonitor, well on bios it says the CPU is running at 61 degrees......... just look at the link and see for yourself..... weird.... why is that and what one should i go by?
http://i192.photobucket.com/albums [...] mptest.jpg
here is another link of CPU-Z
http://i192.photobucket.com/albums [...] ptest2.jpg
now the Vcore goes from that screen print voltage to 1.36V
and my PSU is blowing quite hot air out the back but the rest of the PSU seems to be really cool all over.
Is this a normal setup?
If not how can i improve it?
if you need anymore information. please let me know
Kind Regards
Sean
Sponsored Links
According to ATX specifications, PSU outputs need to be +/- 5%. So your 5 volt output is in tolerance.
I don't know about AMD CPU's, but a 60 C. idle seems pretty high.
Reply to jsc
yeah i was thinking the same also..... tis a little high for it to be idle but upon research it seems "the norm" temp for a 100% stock Phenom.
anyone else got a 9950 phenom here?
if so could you tell me ur idle/load temps.
what about the hot air out of the PSU, is that healthy?
Regards
Sean
Reply to nytrus90
The program you're using could be giving you some weird readings. Try a program like CoreTemp to confirm those temps.
Reply to thefox14
aint that for intel CPU's?
Kind Regards
Sean
Reply to nytrus90
ok scrap what i just said. lol well on coretemp its the same reading as HWmonitor and the bios now reads 51 degrees so i guess all is well on that part.
Now any news about hot air coming out the back of the PSU, is this normal?
Kind Regards
Sean
Reply to nytrus90
Yeah my PSU blows out fairly warm air as well. I wouldn't worry too much about it, but you can always try to add another fan in your case for pretty cheap.
Reply to thefox14
well its on the back of the PSU not an internal problem, is that the same for you, like if you touch the back of the PSU where the hot air is coming out is the metal hot enough to give you a slight tingly burning sensation, nothing major.
Regards
Sean
Reply to nytrus90
no mine feels lukewarm. You might want to use a program like speedfan and get the temperature readings of your case/system. You might have an airflow problem.
Reply to thefox14
hmmm well its abit hotter then luke warm.... speed fan said everthing was kool. hmmmmmm
Reply to nytrus90
well then i wouldn't worry about it at all. But if something funky ever happens in your computer though, you'll know where to start.
Message edited by thefox14 on 07-03-2009 at 02:28:26 AM
Reply to thefox14
Software voltage readings should never be trusted. Use a DMM.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
There are 1297 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
