Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Case fans hooked directly to PSU?
Forum CPU & Components : Power Supplies, Cases & Mods Case fans hooked directly to PSU?
After searching this forum and not finding anything that answers my question directly, I thought I'd ask about my specific question. I hope it's not too basic.
My front case fans are 2 80mm coolermasters. Each one ends in a male and female 4 pin molex connector instead of the small 3 pin fan connector for the motherboard. Can I hook these fans directly to the PSU? The decorative LEDs on the front of the case also end in the same molex M&F header. Can I daisy chain all these together and use just one PSU connector?
I'm somewhat of a n00b, so please be gentle.
Reply to beehew
yes .
direct to molex from the psu
Reply to Outlander_04
Ya you can do that.
I am also using My 2 80mm fans thru 4 pin connectors of the psu and they are running fine.
No harm in it.
Reply to shubham1401
- 0 +
Antec 900 (and I guess 902 and 1200) are designed that way. The only thing you lose is the ability of the motherboard to control and monitor the fans.
Reply to jsc
- 0 +
And I can hook them together and just use one molex from the PSU?
Reply to beehew
Yes you can use them "Daisy chanied" together - case fans dont put a huge drain on a PSU.
The biggest advantage of using the fan headers on a mobo is purely so that the mobo can control the fan speed. If you wanted to you could buy molex - 3 pin adapters to run them this way.
Reply to ulysses35
There are 2048 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cpu Temperatures higher than normal by a far margin !!
By rolli59, 29 minutes ago:
If properly mounted!
Best offers
Top experts
