Tom's Hardware > Forum > Motherboards & Memory > Asus > M4A78T-E Problem...
M4A78T-E Problem...
Forum Motherboards & Memory : Asus - M4A78T-E Problem...
Hi everyone I build my new machine and it not boot at all. No beep, the green L.E.D. is on nothing more.
My power supply have 20 ping plug but the motherboard have 24 pins slot. i dont know if that is affecting the start up. i make a few test like remove the battery, one memory only, no memory etc.
Someone with the same problem? thanks
Sponsored Links
You'll need a 24 pin plug, that's why the system won't boot.
BTW: how many scrapheaps did you have to look through to find a 20 pin power supply? Today even the most crappy power supplies have 24 pins.
------------------------------ CPU: Intel Core i7 920 @3.2Ghz, MOBO: Asus P6T SE, RAM: 3x 2gb OCZ Platinum OCZ3P1600LV6GK, GPU: Sapphire HD 5870, PSU: Corsair HX520W, HDD: Seagate ST31000528AS 1Tb 32mb, COOLER: Scythe Mugen (S775 version), CASE: Coolermaster CM690
Reply to Gulli
- 0 +
Thanks for the response, I buy everything new and the new power supply arrive tomorrow but some people say that psu with 20 pins work if you dont have a pcie videocard so i tried to boot the system.
But is false.
Reply to BoBWILL
There are 1198 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
