Alright, I'm running a I7 930 on an ASUS P6T mobo and in a HAF 932 case.
I want to upgrade to water cooling, as I'm currently using a HYPER n520
I managed to pull off a 3.6 clock, but it nears temps of 90C load at this clock (45-50 idle) , and not even after extensive testing using PRIME 95.
I'm not very familiar with water cooling, but I would like to be able to pull a 4.0 GHZ clock on my system. Don't think I'll do any GPU water cooling down the line, but I may be interested in it.
I plan on getting the GTX 570 relatively soon.
I've been doing research , and I've gathered that just about any water-cooling all-in-one package is usually crap, and the H50 or any knock off is essentially bull****.
So , here is my question, what would be a good water cooling set up for around 100-150 USD?
Well, I know nothing will be good per say at that price range, but what is the best I could do with that? I would be willing to go higher near 200, but I would prefer to avoid that.
I was looking at this, but to be honest I can't find many retailers and scant reviews on it.
http://www.frozencpu.com/products/11432/ex-wat-155/Larkooler_Universal_High_Performance_Complete_CPU_Liquid_Cooling_Kit_BA2-241_Sockets_LGA_775_1156_1366_754_939_940.html?tl=g30c321s1286
Any suggestions?
I don't need to go all-out. Just something entry level to a modest water cooling set up at best. Not really too worried about installation as I'm sure I will be able to figure it out.
Any suggestions?
