Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Graphics card and fan burn out... psu problem?
Forum CPU & Components : Power Supplies, Cases & Mods Graphics card and fan burn out... psu problem?
Ok so i built my first pc and everything went well untill one day like 2 weeks ago it just shut off while i was playing a game. I turned it back on and after a second i saw some sparks and some smoke. After some testing on my second computer i figured out my video card blew out (not a big deal it was a nvidia 9800gt) I ordered a cheap card and some extra fans i added the graphics card it worked fine my pc is running fine then i installed a fan which also worked fine when first plugged it then i unplugged it to reposition it a little and when i plugged it back in it also sparked and stopped working..
Heres my power supply http://www.newegg.com/Product/Prod [...] 6817341011
Also when i look at my processor speed in control panel it says its at 3.21 when it should just be 3.20 Should i be worried about this? Could the psu be sending slightly more power then it should?
Reply to mjz
That psu is one of the best. It sounds like a short. Could also be power coming in from your plug atthe wall, fluctuations, but sounds like a short
------------------------------ If we lose this freedom of ours, history will record with the greatest astonishment, those who had the most to lose, did the least to prevent its happening
Reply to JAYDEEJOHN
There are 2024 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cpu Temperatures higher than normal by a far margin !!
By rolli59, 31 minutes ago:
If properly mounted!
Best offers
Top experts
