Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Other Components > Problem xfx nforce 790i ultra SLI
Forum CPU & Components : Other Components Problem xfx nforce 790i ultra SLI
hey i have a problem when i turn on my computer it just say a strange sounds like biiiiiiiiiiiiiiiiiiiiiiiib
and the screen is black I think self that it is a cable that not sit right but i don't know which cable it is so plz help me
Reply to martinjn1234
my spec is
motherboard: nforce 790i ultra SLI
CPU: intel quad core q9650
GPU:zotac gtx 295
Power supply: ocz gamexstream 700 watt
RAM: ocz 4gb ddr3 2000 mhz
so plz help me I need some help i have use meny money on this gaming rig
does your board have a 2 digit display that throws codes?
Reply to roofus
what is that display showing? anything?
Reply to roofus
that is most likely memory. take it down to one stick of RAM and manually set the voltage required for your RAM kit. the nforce boards default to a lower setting then required for most kits.
Reply to roofus
i have take one out and turn the computer on but it still say the biiiiiiiiiiiiiiiiiiiib sound and the display f6
hmm..try moving the RAM to the slot furthest from the CPU.
do you have that video card seat real good? if so, do you have a test card just to rule it out?
Reply to roofus
hey i know is there a special way how the ram have to be
well mine works in either channel set so that shouldnt be an issue unless you have a bad memory slot. have you tried both sticks, one at a time to rule out a bad sitck of RAM?
Reply to roofus
I solved the problem thx :D man you are greate
cool! glad your in business.
Reply to roofus
it do not make the biiiib sound but show black screen and the display say 08
the screen says 08 or the error display?
Reply to roofus
you may want to take a peek here martin: http://www.ocztechnologyforum.com/ [...] hp?t=37731
sounds very familiar.
Reply to roofus
The owners manual that came with the board should all the codes in it.
Reply to baddad
There are 2021 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cpu Temperatures higher than normal by a far margin !!
By rolli59, 31 minutes ago:
If properly mounted!
Best offers
Top experts
