Tom's Hardware > Forum > Homebuilt Systems > New System Build > New System, Monitor does Not Turn On (Not a Monitor Problem)
Forum Homebuilt Systems : New System Build - New System, Monitor does Not Turn On (Not a Monitor Problem)
I just built a new computer. I will list the parts below.
RAM: http://www.newegg.com/Product/Prod [...] 6820134012
Motherboard: http://www.newegg.com/Product/Prod [...] 6813188036
Processor: http://www.newegg.com/Product/Prod [...] 6819103274
CPU Cooler: http://www.newegg.com/Product/Prod [...] 6835106073
HDD: http://www.newegg.com/Product/Prod [...] 6822136075
PSU: http://www.newegg.com/Product/Prod [...] 6817139008
When I turn my computer on, for some reason, the monitor does not. I have tried using the on board video card and additional video card listed below.
http://www.newegg.com/Product/Prod [...] 6814130419
Perhaps I did not connect something (I double checked but I don't believe this is the case) or something is incorrectly connected.
By the way, I suspect that it is not a monitor problem because the monitor works fine with my other computer.
I really have no idea. Any help is appreciated.
Message edited by sepulveda on 03-31-2009 at 05:36:24 AM
Sponsored Links
i know this is a stupid assumption but....
you are sure youre pluggin in your monitor into your GPU? and make sure you have the proper cables?
also do you have a spare monitor to test to see if that works?
Reply to jaypamps
To the person above me:
It worked before with another Power Supply, but I disconnected everything once I found out that my old PSU wasn't good enough. I had lost the instructions so i reconnected from memory. I am pretty sure all of the important things are pluged in the right places. I only thing I could not remember was the wire to the power button, but I can always turn it on directly from the MOBO anyway.
I heard it might be my PSU? I am really not sure.
Message edited by sepulveda on 04-02-2009 at 08:35:59 AM
Reply to sepulveda
If it worked with a different PSU, then either the PSU you have is defective, or you forgot to plug something in. Go through shortstuff_mt's checklist to make sure everything is connected.
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
If it turns out to be the PSU, should I buy one with more wattage or would 400 be sufficient?
Reply to sepulveda
400w is plenty. Are you just using onboard video?
GTX 260 Core 216
Reply to xthekidx
There are 1213 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
