Tom's Hardware > Forum > CPU & Components > CPUs > Cpu temps help
Cpu temps help
Forum CPU & Components : CPUs - Cpu temps help
:o ok i have an Q9300 now i ran prime 95 for a bit and hear are my temps
98.9% Load
Temperture
cpu 1 66 cpu 2 58 cpu 3 60 cpu 4 61
now the tj max that core temp says is 100C for my cpu and my cpu idels at around 42 to 45 now i live in orange county city of santa ana so it hot even at night most of the time right now my rom temp is 73c, nos since my max is 100c i should be good right i don't think the fan is stock it looks pretty big it's a gateway computer
Sponsored Links
Room temp 73 degree celcius?I don't think so.
But since the place is so hot then i think the temps are okay cuz i also live in a warm place and my proccy idle's at 40c and full load 60c.
So its fine.
Reply to shubham1401
- 0 +
If you are seeing those temperatures under Prime load you should have no problems under normal operation.
As a guide, expect the CPU to be 10-20C above ambient at all times.
------------------------------ Peace cannot be kept by force, it can only be achieved by understanding: Eienstien
Reply to coozie7
Sorry i messed up the room tmep in my house is 70F i was half asleep when i wrote this post, So my temps sould be okay, now i haven't tried gameing on it but i guss the temps would be the same thats if the cpu hits 98.9 load like it did on prime 95 :o
Reply to Peter2004
Do you have stock HSF or an aftermarket cooler?
- 0 +
Shubham-The OP doesn't know because its a gateway. Said it looks "big".
Reply to buzznut
There are 1038 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
