Solved
Are these temps normal at this speed?
December 10, 2010 1:04:21 AM
im using a cooler master hyper 212 plus, i am overclocking and i am currently sitting at like 70c in prime 95, i idle at like 40. The processor is at 3.6ghz and i am at 1.26 volts. Are these temps high, or normal? and should i up my voltage?
motherboard asus p6x58d-e
More about : temps normal speed
a c 241 K Overclocking
December 10, 2010 1:06:45 AM
high..! don't increase voltage
check again your installation HSF & Thermal Paste Fix it !
m
l
December 10, 2010 1:09:09 AM
so should i reapply thermal paste and try again?
m
l
December 10, 2010 1:24:42 AM
if u want to fix it ! temp 70C still Save
m
l
Best solution
a b K Overclocking
December 10, 2010 2:25:42 AM
You are fine ,when you get to 90's..I would stop
December 21, 2010 1:27:47 AM
Best answer selected by pukaslukas963.
m
l
December 22, 2010 8:00:31 AM
You should say what CPU you are overclocking also. I wouldnt like 70C on aftermarket cooling
m
l
