Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Is there a way to turn the GPU off when the monitor is not running?
I don't see why the GPU fan should be working long hours when I am downloading stuff and the monitor is off ?!,help please..
Sponsored Links
You video card is always being used, not until you shut your system off. So regardless it being idle the graphic card needs constant cooling. Usually cards clock down when not in use so it saves power, as for the fan you can control it yourself and drop the speed (rpm)
Reply to invisik
Just because you turn your monitor off does not mean that the GPU stops sending a signal down the cable.
------------------------------ Exchange Engineer - Why is it that when DNS goes down everyone thinks it's my exchange server?
Oh ya, email is the heart of work.
Reply to boonality
There are 1313 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
