Help me with fans/cpu cooling
So can i just buy 10 of these since its so cheap and add them to an external psu without plugging them into the mb? just use the 4 pin connector on them in the picture? i just want them to run at a 100% i could care less for fan control...
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150007
Also if someone could help me find the best cpu cooler for my amd 6000+ windor...i want cheap but i don't want to sacrifice for cooling...so something not to cheap and not to crappy...thanks
BTW its an AM2 mb...
2 answers Last reply
More about help fans cooling
  1. Yes, you could, but why would you?
    The cooling gains would be minimal and the noise would be unbearable.
  2. The cooling gains would only be minimal if i actually had decent fans in the pc? yeah
    And the noise would only be audible if my room wasn't already filled with fan noise...mhmmm
    Im thinking 10 of these and i can run half along with a new cpu cooler...
Homebuilt Cooling CPUs Fan Controller Systems Product
