Hello guys,
I recently built a quad core gaming system for a customer.
Here are the specs:
OCZ Stealth XStream 700W PSU
Gigabyte GA-EP45T-DS3R iP45 Socket 775 8 channel audio ATX Motherboard
OCZ 2GB PC3-14400 DDR3 Platinum (2x1GB)
Sapphire HD4870 512mb PCI-E
Intel Core 2 Quad Q6600 G0 SLACR, Kentsfield Core, Sok 775, 2.40GHz, 1066MHz, 8MB Cache, OEM
750 GB Samsung HD753LJ Spinpoint F1, SATA 3Gb/s, 7200 rpm, 32MB Cache, 8.9 ms, NCQ
Coolermaster CM-690 V2 Dominator Black Midi Tower Case with Mesh Top Panel w/o PSU
Akasa AK-975 Intel LGA 775, 2U shape Heatpipe cooler with Lo-noise side blow PWM fan
The CPU is having no problems overclocking, since I was able to push it from 2.40ghz to 3.3ghz, whilst keeping the ram down below 1300mhz.
The ram is PC3-14400 which is meant to run at 1800mhz and beyond.
However, I can't even post the system beyond 1400mhz. I set the voltage to 1.9V...OCZ recommends a maximum of 2.0v, but thats for overclocking! I can't even get anywhere near its rated speed. I set the timings to 8-8-8-24.
Here is the OCZ page for the ram: ocz_ddr3_pc3_14400_platinum_edition
Even at 1400mhz, the system crashes after an hour of gaming, which then currupted windows.
Is there a chance the ram is faulty? If i was to return it, and Aria.co.uk tested it as 'working' they send you back the same parts!
Here are the specs:
