Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need an alternative power supply for dell xps 435
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Need an alternative power supply for dell xps 435
Hi guys,
i have specced up del xps 435 with 6 gig ramm and ati 4870 1 gig video card. i beleive the system comes with just 475watt power supply. Could someone suggets the best replacement power supply unit?
thanks
Sponsored Links
Looks like the video card came with the system. If your system is stable, and games are running smoothly on high settings, I would leave it alone. Dell has pretty good power supplies on it's high end systems. Only reason to upgrade the ps is if you overclock. I don't know if the board permits this. If you decide to upgrade the ps, corsair, pc power and cooling, antec, seasonic, enermax, and ocz are all good brands. Expect to spend about $100-150 for a 750w ps.
Reply to o1die
i've had my 435 for about a month. after constant lockups/freezing issues and hours on the phone with dell's useless tech support i thought i'd try a psu. it's run problem free for a week now. i got a thermaltake 850 watt from best buy for 160.
I'm running the same vid card, 8 gigs of ram and the 940 processor.
Reply to dngr1179
As much as I like Corsair several people have posted at both the DCF and Corsair forums that the Corsairs are not working in the new Dells.
The Antec Earthwatts seem to be the favorites at this point.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
There are 1194 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
