My brand new custom built pc specs
Intel core 2 quad q8200
Gigabyte ep45 ds3p bios f8
650w psu i green power
1TB HDD
2x2048mb 800 mhz corsair memory ( problem)
1024 mb corsair ram
When i connect the 2 dual channel memory ram chips in the motherboard the system becomes unstable and doesnt boot successfully
when i just connect the 1 gig ram on it own the system boots perfectly
what is the problem
is there some sort of settings in the bios i must change?
BTW i am only 14 years old so i will not understand everything about the bios but im okay
thanks in advance
According to CPU-Z, how is it configured (Memory tab)? What SPD tables are available? According to Corsair: "Tested at the low latencies of (4-4-4-12) at 2.0V". Are you running them at 667 MHz with the correct voltage and latencies?
Dram frequency is 333.3mhz
FSB 1.1
Cas latency:5.0 clocks
Ras ro cas latency:5 clocks
Cycle times 15 clock
Row refresh cycle times: 36 clocks
Comand rate 2t
That is the full spec it is showing
new 2 gig ram info is Part number
cm2x2048-6400c5
800mhz btw
What do you mean? Are you trying to use one CM2X1024-5400C4 (667 MHz, 4-4-4-12 and 2.0V) module and one CM2x2048-6400C5 (800 MHz, 5-5-5-18 and 1.9V) module at the same time? If so, then you need to configure the RAM as per the CM2X1024-5400C4 specs and hope for the best. Unfortunately you didn't provide that important info in your original post.
Unless you run a 64 bit OS and you really need more than 4 GB, only use the 2 GB modules. If you need to use all three modules, then try the settings that I recommended.
You wrote "if not both 2 gigs are fine , so I'm confused. It doesn't work with both 2 GB modules or it doesn't work when the 2 GB and the 1 GB modules are installed?
So if you install a single 2 GB module, it won't boot at all? If so, then they either are defective, incompatible or your RAM settings are not on Auto. Reset all memory settings to Auto or reset the CMOS.
nope looks like it was the same issue. i checked corsairs site and it is completely supported.
i will send it to corsair for repairs cuz of the life time warranty
