What is a good air cooling system? i plan to OC my cpu to 4.0GHz
  • Heatsinks
  • Cooling
  • CPUs
  • Overclocking
  • Product
December 14, 2010 9:21:18 PM
what is a good air cooling system? i plan to OC my cpu to 4.0GHz
-CPU is i7 950
-mobo rampage iii
-RAM yea... i need help with that too
-7 case fans
-1000W PSU
+ can you direct me to nice thermal paste and a good heat sink too!
i have a $3200 budget for my computer
More about : good air cooling system plan cpu 0ghz
December 14, 2010 9:47:33 PM
wow $3200 budget that's quite alot
firstly, cpu options: i would wait until sandy bridge comes out in a few weeks and see if they're better, second the gigabyte ud9 is a bit better than the asus rampage III
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Corsair Dominator you can ditch the fan because it's useless and go down in the range if you want
Another good set of ram would be Kingston Hyper-X sets
NOW
you might have to check RAM clearance but the promalitech megahalems is probably the best air cooler out there, run it in push/pull you'll get to 4.2 GHz no problems
if you want to go with the standard, get AS5 thermal paste
but if you wanna go out there, go for indigo xtreme, it's not on newegg but you can go on their website and find some dealers
m
l
December 14, 2010 9:49:08 PM
Here is a great thermal paste
http://www.newegg.com/Product/Product.aspx?Item=N82E168... Artic silver 5
As for an air cooler try this one
Prolimatech Megahalems Rev.B CPU Cooler
you'll need a good fan for this as well, you could try this fan as it receives good revues and pushes alot of air at reasonable noise levels.
SILVERSTONE FM121 120mm Case Fan
Hope this helps and enjoy the build!
m
l
a b à CPUs
a b K Overclocking
December 15, 2010 1:45:43 AM
With $3200 budget why don't you go with liquid cooling?
m
l
December 15, 2010 11:38:41 AM
i don't want to put up with liquid cooling and i would rather spend the $300 for liquid cooling on buying a graph card that is $200 more and high-end parts. i just spent 200 on a monitor so now i only have 3000 left in my budget for this computer.
thanks!! for all of you responses
m
l
December 15, 2010 3:53:52 PM
Qty. Product Description Savings Total Price
Item #:N82E16835242001
Return Policy: Standard Return Policy
-$7.99 Instant
$69.99
$62.00
CORSAIR HX Series CMPSU-1000HX 1000W Compatible with Core i7 Power Supply
Item #:N82E16817139007
-$50.00 Instant
$20.00 Mail-in Rebate Card
$279.99
$229.99
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Item #:N82E16811119225
$199.99
CORSAIR DOMINATOR GT 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory
Item #:N82E16820145318
Return Policy: Memory Standard Return Policy
$479.98
XFX Radeon HD 6970 HD-697A-CNFC Video Card with Eyefinity
Item #:N82E16814150517
Return Policy: VGA Standard Return Policy
-$10.00 Instant
$779.98
$759.98
GIGABYTE GA-X58A-UD9 XL ATX Intel Motherboard
Item #:N82E16813128446
Return Policy: Limited Replacement Only Return Policy
-$100.00 Instant
$699.99
$599.99
Intel Core i7-950 3.06GHz LGA 1366 130W Quad-Core Processor
Item #:N82E16819115211
Return Policy: CPU Replacement Only Return Policy
-$5.00 Instant
$299.99
$294.99
Grand Total: $2,626.92
m
l
December 15, 2010 3:56:13 PM
^ my suggestion
m
l
