Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > P5Q with 8GB of RAM - Voltage help
Forum Motherboards & Memory : General Motherboard - P5Q with 8GB of RAM - Voltage help
Hi guys,
I was wondering if someone could point me in the direction for system stability :)
My machine looks like this:
Asus P5Q Deluxe
Core 2 Quad Q6600 2.4GHz S775
EVGA GeForce GTX 295
4x2GB 240DIMM PC2-6400 Gold
I have recently upgraded, adding the GTX 295 and an extra 2x 2GB sticks of RAM. Prior to this upgrade i was fine however now i am seeing quite a few 'Exception code: 0xc0000005' AppCrashes in high-load games. The secondary use of my PC is music production, but my sequencer and plugins are all 32bit. I see perfectly stability in these programs and in Windows in general.
Seeing as the only application error i am seeing is 0xc0000005, i would like to investigate RAM voltage\timings and general voltage issues before i look at other things.
I have recetly upgraded from Vista 64bit to Windows 7 6bit and am seeing exactly the same issue, so i am fairly convinced there is a hardware issue (be it a fault, or misconfiguration).
Could this potentially be a voltage\timing issue? My timings are set to 5-5-5-18 with a DRAM voltage of 2.1, which look to be the spec for my RAM. I have left the NB voltage well alone. Any tips or pointers for diagnopsing this issue woiuld be greatly appreciated.
Sponsored Links
Did you run memtest for several hours? Do you still experience that error if you go back to 4 GB? What if you go back to the previous video card? Is your PSU up to the task? After all you seem to get the issue only when running games and that could indicate an issue with the PSU or the GPU.
Reply to GhislainG
There are 530 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
