I have an Asus 4850 Glaciator and it's great but the fan noise when it's idling is very loud and very unnecessary as it's idling under 38 Degrees.
I know i can manually lower the fan speed through ATI CCC but this means you have to remember to manually adjust the fan all the time when using applications/games. My question is:
Is it possible to make a profile edit that will set the default idle speed to whatever i want but will, also, still allow the fan to automatically speed up when it's under load?
I've tried some profile edits but they rigidly stick the fan to one speed.
There may be a VGA BIOS flash for your card. I was at the Asus site but didn't specifically see the "glaciator name" but did see a BIOS update for an HD4850 concerning overheating ( fan control ).
Again, you MUST flash the correct BIOS.
I've heard some people say their fan control worked in XP or Vista but not the other way around.
Of course ensure you have the latest video drivers from the AMD site. Actually you want to update the entier "suite" which is basically the Drivers and CCC.
I can't think of any other advice. There may be custom fan-speed controls like speedfan but I don't recommend that route nor do I think I know of much usage (yet) with graphics cards.
Message edited by photonboy on 04-25-2009 at 01:55:20 PM
An Asus should come with that smartdoctor (or something) software that lets you set your own fan speeds depending on temps. If not, you can do it on rivatuner.
Thanks jennyh, my bad, i neglected to mention I’m still testing what's been a very challanging build (1 faulty gfx card rma'ed and faulty memory) which is why I haven’t installed smartdoctor. I've always used the ATI drivers from AMD and so have always used CCC. Smartdoctor will probably have to be an option to explore if i can't tailor CCC to my needs.
Strangerstranger, my temps have hit 65 degrees in furmark when using the manual mode but no change in fan speed - i figured it should have kicked in by then if it was going to. When i use the auto setting the fan kicks in as soon as temps begin to rise - and that's from a starting point of 40 degrees.
Thanks photonboy i'll look into the BIOS option - but it sounds like mine has the new BIOS as it runs very cool - even under load. I haven't seen it go above 70 degrees yet. Oh, and see sig for spec and drivers.
Plec
Message edited by plec on 04-25-2009 at 02:32:04 PM
------------------------------CPU: Intel Dual-Core E5200 Motherboard:Gigabyte GA-EP43-S3L BIOS: F8 Memory: Kingston DDR2 4gig 8500 (2 x 2gig)Gfx: Asus 4850 512 Glaciator 9.4 cats Soundcard: Onboard HDD: 1x 300 Gig 2 x 120 Gig SATA [b]OS
Reply to plec
If that's the case i wouldn't use it - as i would like the fan to kick in around 70/75 degrees at the very latest.
Odd that it kicks in immediately on auto mode with the fan idling at 50% but yet in manual mode it waits until the gpu temp is just 20 degrees off critical.
Seems nuts - in my over cautious and conservative view.
Thanks for getting back to me on that strangerstranger - appreciated.
Plec
Message edited by plec on 04-25-2009 at 03:10:12 PM
Reply to plec
