As the title suggests I am looking at both of the above power supplies for a build I am doing. They are almost identical in price. Was wondering if there was any difference in quality other than one is modular?
The Stealth series usually have fewer connectors and are marketed more for a budget build. Make sure you count what connectors you need and see if it has enough. For some OCZ power supply reviews check.
http://www.jonnyguru.com/
and http://www.hardwaresecrets.com/page/power
