Same problem with my computer - do i need a network card?
Hello,
My Acer Aspire 5100 is having a similar problem. I freshly loaded windows xp onto after cleaning the hardrive and reformatting it.
Now on startup it reads "Resource Conflict - PCI in Slot 3". When it says this i need to hit F1, then start windows normally. When it does this it freezes and does not start up. When the warning "Resource Conflict - PCI in slot 3" does not come up, then i go to start windows normally, and it will start up.
Below is the text that is coming up under the MSINFO32 Conflicts area.
I hope you can help me.
thanks so much for your website - its such an amazing resource!
Bradley
Vancouver, BC, Canada
I/O Port 0x00000000-0x00000CF7 PCI bus
I/O Port 0x00000000-0x00000CF7 Direct memory access controller
I/O Port 0x000003C0-0x000003DF PCI standard PCI-to-PCI bridge
I/O Port 0x000003C0-0x000003DF VgaSave
IRQ 10 PCI FLASH Memory
IRQ 22 Standard Dual Channel PCI IDE Controller
IRQ 22 Atheros AR5004G Wireless Network Adapter
I/O Port 0x00009000-0x00009FFF PCI standard PCI-to-PCI bridge
I/O Port 0x00009000-0x00009FFF Video Controller (VGA Compatible)
Memory Address 0xE0000-0xE1FFF PCI bus
Memory Address 0xE0000-0xE1FFF System board
Memory Address 0xB0100000-0xB01FFFFF PCI standard PCI-to-PCI bridge
Memory Address 0xB0100000-0xB01FFFFF Video Controller (VGA Compatible)
IRQ 19 Standard OpenHCD USB Host Controller
IRQ 19 Standard Enhanced PCI to USB Host Controller
Memory Address 0xC0000000-0xCFFFFFFF PCI standard PCI-to-PCI bridge
Memory Address 0xC0000000-0xCFFFFFFF Video Controller (VGA Compatible)
Memory Address 0xA0000-0xBFFFF PCI bus
Memory Address 0xA0000-0xBFFFF PCI standard PCI-to-PCI bridge
Memory Address 0xA0000-0xBFFFF VgaSave
I/O Port 0x000003B0-0x000003BB PCI standard PCI-to-PCI bridge
I/O Port 0x000003B0-0x000003BB VgaSave
2 answers Last reply
More about same problem computer network card
  1. BradleyCanuck said:
    Hello,
    Bradley
    Your post is from 11 days ago; hopefully you no longer need help !
    Did you go into Device manager & Look for the Question Mark in yellow, for devices that have an error ?
    Also, in BIOS, there is a setting for detection: Auto/Manual. Set it to Auto.
    Can you move the slot 3 PCI card to another slot ?
    As a last resort, you may have to backup presonal files, reset to factory settings, clean reinstall your OS & reinstall necessary drivers.
    PS: I see this symptom reported a number of times for your make/model.
  2. Thanks for your response.
    I actually returned it to the store i bought it from - i had just bought it a few weeks earlier.
    Apparently, someone at the store said that this is a common error message when these laptops are breaking down too, which was interesting because the machine was also getting really hot - not sure what was up with the fan and heat.
    It got this error message less often with running Ubuntu on it afterwards, but it was still happening.
    My lesson - DONT BUY A LAPTOP THATS MANY YEARS OLD!!! laptops dont have the longevity that a desktop has. So its just best to go new, and probably get an extended warranty
    Thanks for your help anyways
    Bradley
PCI Network Card Memory Windows XP
